Open headers and o2 sensors
Old Jul 25, 2003 | 06:30 PM
thewinner's Avatar
my plan is to put a cutout after each collector for some open header sound. id probably only uncap it occassionally.
is this gonna **** with my o2 sensors and make the car dump lots of fuel into the motor?
Old Jul 25, 2003 | 07:16 PM
turbo_Z's Avatar
i think as long as you have the cutouts placed a good foot or so after the O2 sensors, you wont have any problems.
Old Jul 25, 2003 | 07:37 PM
thewinner's Avatar
how long is the average cutout? and how long is the part the exhaust comes out?
Old Jul 25, 2003 | 10:30 PM
thewinner's Avatar
is this redundant with my no cats/open borla setup? will i actually notice a difference with the cutouts right at the collectors? i thought it would pick up some power and lots of sound right?
Old Jul 25, 2003 | 10:42 PM
colorchange96's Avatar
IMO, running exhaust sounds better than open headers. you probably wont pick up much if any over a 3" catback with no cats. if you ran duals with an equalizer of some sort you might pick up an extra 5-15hp.
Old Jul 25, 2003 | 10:58 PM
thewinner's Avatar
i was mainly gonna do it for the sound occassionally. i truly believe that at the higher rpms, it would pick up a decent amount of power?
Old Jul 25, 2003 | 11:19 PM
do you have a stock cam? if so the open header sound sounds loud, but not good. it would be a waste of money to me.
Old Jul 25, 2003 | 11:30 PM
thewinner's Avatar
nope its a 383 motor
Old Jul 26, 2003 | 01:28 AM
96LT14u2Nv's Avatar
your knock sensor is what will mess with it by retarding timing. i programed mine out, i just have to listen for "pings" now
Old Jul 26, 2003 | 04:56 PM
thewinner's Avatar
I think im just gonna stay with the open borla, should be plenty loud right?
Cutouts by the collectors would just be a pain most likely...
Old Jul 26, 2003 | 05:26 PM
Brettinator's Avatar
I have JetHot LT's with dual 3" FlowTech cutouts about 8" after the collector flanges. When in closed mode it runs through a custom 3" ypipe into the 3" open Borla. It sounds mean both modes but sounds like a NASCAR with open cutouts . But! with stock heads and cam you'll definitely lose some rwhp due to lack of backpressure, I lost 2/10ths in the 8'th mile and the same in my 60' times with the coutouts open. Again it sounds great and when you do a set of AFR heads and a beasty cam running open headers the backpressure is not an issue any longer....especially if you go ahead and do a stroker
oh yeah...this setup had no effect on the 02 sensors. It was a gamble I took with this setup knowing I'd probably lose backpressure but I knew the stroker was in it's future. My exhaust was setup with the future in mind therefore.
Old Jul 26, 2003 | 05:46 PM
thewinner's Avatar
hmm. I do have a 383. maybe i will have to get some. any pics of where you put the cutout on the drivers side?
Old Jul 26, 2003 | 06:36 PM
same place as my pass side cutout about 8" aft of the header collectors. It's a sweet setup. Now if I can get my miss/sputter/rich condition under control I'll be happy.
Old Jul 26, 2003 | 07:05 PM
thewinner's Avatar
what is the length of the total cutout? gotta see if i have space for them. is it a big noticable difference in sound and power?
Old Jul 26, 2003 | 07:43 PM
thewinner's Avatar
decided not to get them, ill just run the open borla for now. motor is going in the car sunday and i cant get em here till tuesday so just gonna skip it now.
Thanks for all the help!
