open circuit, on o2, please help
Old Nov 22, 2004 | 05:06 PM
LEATHAL Z's Avatar
http://web.camaross.com/forums/showthread.php?t=319795
Old Nov 23, 2004 | 06:59 AM
slopokrodrigez's Avatar
Re: open circuit, on o2, please help
Driver side O2 has 2 wires going to the PCM. The low side of the signal is on PCM connector C which is white on pin 19. Wire color is tan/white. The high side of the signal is on connector C pin 20. Wire color is purple/white. If the splice location is in a tough spot, pull the harness up through the top of the engine bay toward the master cylinder and do the work from the top.
Make sure if you splice wires that it is done between the PCM and the connector. DO NO splice wires between the O2 and it's connector. The O2's use the wires to receive the oxygen it requires. Use solder and heat shrink tubing.
If you are using an ohm meter, unplug the PCM. Since ohm meters use voltage, if left plugged in, you chance damaging the PCM.
Dave
PS, how about making a signature so we know what you're driving the next time we help with a question?
Old Nov 23, 2004 | 08:44 AM
LEATHAL Z's Avatar
sorry about that 95 z28...thanks for the help
NewsBot
Sep 30, 2015 04:20 PM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
marlar98
Sep 19, 2015 07:53 AM
Toxintwins
Sep 11, 2015 11:13 AM
