Ooops! I cut the wrong wire trying to install a tach!
Old Apr 10, 2005 | 09:48 PM
Mullet Z28's Avatar
I used this guide from Shoebox's site:
http://shbox.com/1/keyless_entry.jpg
Because I'm an idiot, instead of splicing into the white wire in the C230 cluster, I cut the gray wire. The car seems to be running OK. Can someone please tell me what the gray wire is for?
Old Apr 11, 2005 | 12:18 AM
Re: Ooops! I cut the wrong wire trying to install a tach!
According to Shoebox's harness diagram and his wiring diagrams, appears there may be some gray wires routed through C230 supplying reference voltage to the A/C evaporator temp sensor. Did you check to see if your A/C works OK?
Old Apr 11, 2005 | 09:48 AM
Mullet Z28's Avatar
Thanks for the reply, Fred.
I haven't recharged my A/C yet since getting my motor back together, so don't know if it works. I suppose the only thing to do now is splice it up and hope for the best.
BTW, what exact function does the evaporator temp sensor perform? Obviously it's a temp sensor, but what does the A/C system use the temp reading for?
Old Apr 11, 2005 | 12:19 PM
Heatmaker's Avatar
Advanced Member
Just sauder the wire back together.
Old Apr 11, 2005 | 02:18 PM
The PCM gets the signal from the evaporator temp sensor. Not sure how it uses the info.
"solder"
Old Apr 11, 2005 | 05:39 PM
NOMAD's Avatar
Originally Posted by Injuneer
"solder"
I was never surprised when I took over Auto Tech manager at how many people pronounce this wrong that have been "mechanics" for years...lol
-Shannon
mr28
Apr 20, 2016 05:44 PM
jayvar
Feb 2, 2015 10:00 PM
ldtantlinger92
Jan 19, 2015 01:26 PM
mr28
Nov 23, 2014 11:11 AM
CobraEatr
Jul 23, 2002 06:32 PM
