only closedloop?
Old Jan 3, 2005 | 01:35 PM
sw89lt1's Avatar
only closedloop?
the motor is a 95 out of an impalla in a 89 camaro. pcm was reprogramed by pcmforless; deleted egr, air pump, auto trans
today i left work, drove about 5 miles and it started running like crap until i gave it about 3/4 throttle. it does the same no mater what rpm i start giving it more gas.
It seems like when the computer is in openloop or P.E. mode it runs fine.
i unpluged the 02 sensors and drove it and it runs fine.
should i contact pcmforless or what?
ps tried to search.
Old Jan 3, 2005 | 02:04 PM
aintno6's Avatar
Re: only closedloop?
How old are the o2 sensors? What brand are they? Are they heated or non heated o2 senors?
Mike
Old Jan 3, 2005 | 02:08 PM
sw89lt1's Avatar
as far as i know they are stock heated sensors.i had a baby lt1 1 in the car befor and had no problem with sensors.iv'e had this motor in for about 3 weeks
Old Jan 3, 2005 | 02:43 PM
aintno6's Avatar
well concidering your pcm runs off the o2 readings the minute it goes into closed loop, I would replace those o2 sensors to start off with .
I was able to get them for like 70 bucks off gmpartsdirect.com
Mike
Old Jan 3, 2005 | 03:51 PM
Before you start replacing parts, check for sources of "false" O2 readings..... things like misfires, exhaust leaks before the sensors, leaking injectors, faulty wiring and interference from nearby high voltage wires can throw the sensor readings "off" to the extent the car runs poorly.
Do you have a scan log that we can look at?
Old Jan 3, 2005 | 07:25 PM
sw89lt1's Avatar
thanks for the input guys i'll keep you posted.
Old Feb 27, 2005 | 05:53 PM
sw89lt1's Avatar
i finally got time to fix this problem. it turned out to be a small exhaust leak before the o2 sensor.
Old Feb 27, 2005 | 11:50 PM
Thanks for the feedback... you would be amazed how few people ever come back and tell us whether the suggestions worked.
