Which one is the return line?
Old Mar 13, 2005 | 06:56 PM
Droff's Avatar
On the Trans cooler in the radiator which one , the top or bottom, is the RETURN to the trans line?
Thanks.
Old Mar 13, 2005 | 09:21 PM
trans9_5am's Avatar
Re: Which one is the return line?
I'm assuming the bottom line. Wouldnt you want the fluid to be pumped into the radiator and then flow out the bottom line back to the tranny? Not sure but this is what i would think. Ill try to look it up for sure.
Brandon
Old Mar 13, 2005 | 09:22 PM
amean94ta's Avatar
follow it back the front is the out going the back is the return
Old Mar 13, 2005 | 10:04 PM
Fluid flows from the transmission to the radiator on the lower hose and returns on the upper hose.
Old Mar 13, 2005 | 10:14 PM
Droff's Avatar
Thanks, I wanted to make sure I put the external trans cooler in the right spot.
Old Mar 13, 2005 | 10:22 PM
trans9_5am's Avatar
Haha guess i was wrong....Sorry.
Brandon
Knightscrapper
Feb 4, 2016 10:25 AM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
4586
May 28, 2015 01:30 PM
Victory Racing
Sep 12, 2002 10:40 AM
