Once-Twice Daily no start issue
Old Nov 17, 2008 | 01:23 PM
stephenspann27's Avatar
This used to happen about once a month, now it happens every day during my lunch break.. and once in a while at random times.
I turn the key and the starter will not turn over. It's as if I don't have the clutch pushed in.
I have VATS disabled via madz28 tune. I removed the TDR and connected the purple and yellow wires. I removed the clutch switch.. (this is over ridden by my TDR deletion anyways). I also replaced the starter.
Every time this happens I end up rolling down a hill and letting the clutch out ( I always park in hills just in case). I think if it were a security issue the car would not able able to start. I don't get a security light either. If the starter would engage it would crank..
Old Nov 17, 2008 | 01:33 PM
bigbirdta94's Avatar
do all of your dash lights come on??? if they do check your ignition switch....i had a problem where mine would intermittently not let the vehicle start
Old Nov 17, 2008 | 02:11 PM
ignition switch
yes they do all come on. So I need to take the column apart?
Old Nov 17, 2008 | 02:38 PM
not really take the column apart... just drop it and check to see if you have proper power....did you check the starter yet. if not check that first, it's alot easier then dropping the column
Old Nov 17, 2008 | 02:41 PM
starter
I've replaced the starter.
Old Nov 17, 2008 | 02:45 PM
def check the ignition switch it's really not that bad to get to once you drop the column...there's 2 bolts that hold the column up and once you take them down you should have enough room to get in there and disconnect it....if you have a power probe test the switch if you dont i think the switched arent to expensive
Old Nov 17, 2008 | 03:00 PM
Allright, I hate that it is intermittent.. when I test it with probs it might test good.. even though it faulty.
Are there any other relays or anything that it could be?
Old Nov 17, 2008 | 03:05 PM
yea that what i did with mine...everytime i tested it, it was ok but i just said f**k it and put the switch...havent had any problems since
Old Nov 17, 2008 | 04:48 PM
Are you talking about the lock cylinder..? that whole unit?
Old Nov 17, 2008 | 06:14 PM
no there is a ignition switch that sits on the top of the steering column...once you drop the column you can pull the connector out and check it make sure you're getting the right power...if you have something to check it
Alex Barnes
Jan 24, 2015 10:21 PM
David Dorris
Jan 17, 2015 08:10 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
deadmanrunning
Jan 3, 2015 01:12 PM
Snoman73
Nov 17, 2014 07:22 PM
