OMG!!!! look what i did.....
well me and my buddy were changing valve springs to put on some 1.6RR, we did 3 springs without any problems went very smooth, i was using the screw type compressor and putting compressed air into the cylinder. but here is the problem i believe i was using an air brush compressor. it only puts out like 30psi...lol..when i was puttin the seal on the 4th spring....it went down into the cylinder
i was like holy spit!
well since i have to pull the heads anyway. i am going to send them to lloyd for full porting and bigger valve. and better springs and throw in a XE224/230 cam, a little sooner than i planned on doing heads/cam but i refuse to take the heads off for no good reason!
but now i get to have 350+rwhp from my "little" lol accident...
for everyone out there do not use a small air compressor to change springs
unless you are ready to pull the heads...
actually it only took 2 of us about 8 hours wasnt that bad, but we havent pulled the cam yet, had to go back to work
jesse
i was like holy spit! well since i have to pull the heads anyway. i am going to send them to lloyd for full porting and bigger valve. and better springs and throw in a XE224/230 cam, a little sooner than i planned on doing heads/cam but i refuse to take the heads off for no good reason!
but now i get to have 350+rwhp from my "little" lol accident...for everyone out there do not use a small air compressor to change springs
unless you are ready to pull the heads...actually it only took 2 of us about 8 hours wasnt that bad, but we havent pulled the cam yet, had to go back to work
jesse
Doug Harden
29
Jul 30, 2003 07:05 AM
