OMG!! Another CC306 Thread!
Old Nov 11, 2007 | 08:02 AM
  #16
93transam1234's Avatar
Originally Posted by slomarao
whats streetable to one guy isnt to the next so what you exactly mean by steetable?
....Well my wife also drove it and never complained. I just drove it like i did when my car was stock, it had more power up top and was pretty loopy down low but i didnt really notice and cam surge...tnx to madz28 and the fact i had a auto trans
Old Nov 14, 2007 | 07:54 PM
  #17
slp223's Avatar
I used stock studs with comp 1.6sa rockers no problems. been in the car since may 02
Old Nov 14, 2007 | 08:20 PM
  #18
Bersaglieri's Avatar
7/16 > 3/8 > Stock 3/8
The wont necessarily fail, but they will flex more. Probably not necessary on smaller cams, but I'd go for it on the big boys.
-Dustin-
Old Nov 14, 2007 | 10:33 PM
  #19
Pyrodawg's Avatar
thank you kind sir, thats all i needed to know
Old Nov 15, 2007 | 08:34 AM
  #20
dangalla's Avatar
that is not recommended and cutting corners on something so cheap like that is just silly, your leaving power on the table.
Old Nov 15, 2007 | 11:48 AM
  #21
Vicious95Z28's Avatar
If you get NSA rockers and decide to upgrade the valve train a lil later you will be better off. EX. let's say that you need to jump your install height .050, you can do that with +.050 locks and the correct retainers, this works great but leaves you with less area from the top of the locks/retainer to the top of the valve. So, in this casr NSA's would be better to have.
I'd also recommend the 7/16 studs over the 3/8 especially with the extended rpm range that the cc306 will operate in, they will be more stable (less flex) Trick Flow has a better set of Guide plates to use with NSA's.
Old Nov 16, 2007 | 04:51 PM
  #22
slp223's Avatar
i did not plan to used the parts I did but at the time comp 7/16 rockers are were on national back order with no set date on when they would be avalible. So I used the parts I could get I have no regrets and they have been on my car working for almost 5 1/2 years they have out lated a 12 bolt rear end, a t56 and three clutches. so they have seen lots of hard duty. that is real world expericne not theroy. sure 7/16 are bigger and stronger but are they nessary? at this point i have not reason to beleive so.
Old Nov 18, 2007 | 06:06 AM
  #23
Randy L's Avatar
Following the recommendations, I've decided to go with 7/16". Looking at Summit's site, I can't seem to find the GMMP 7/16" guideplates. The only one I found is for a big block. They sell them individually...how many will I need? I'm thinking 8 sets.
Is this the right one?
http://store.summitracing.com/partde...0&autoview=sku
Also, I couldn't find the 7.2" pushrods in 7/16" size. If someone can provide a link to the proper hardened pushrods for the CC306 & 1.6 rocker setup, I'd be forever grateful!
I totally forgot about hydraulic lifters. What would be the best for this setup?
I really appreciate all the help in making sure my LT1 with stock heads & valves gets the right components for the CC306 cam.
n2oblkz
Oct 22, 2015 02:31 PM
Double aught
Oct 2, 2015 11:29 PM
Z Power
Sep 19, 2015 11:19 PM
Formula Steve
Sep 19, 2015 08:48 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
