Okay, so I broke my timing chain....
Old May 8, 2003 | 05:51 PM
BradZ28's Avatar
After breaking my timing chain I am being told that I very possibly damaged some valvetrain parts (valves specifically) so what I'm wondering is there any way to chack to make sure everything is still ok without taking the heads off? Also could I have damaged the piston tops for any reason?
Oh, and everyone that does an opti change I would recommend a new timing chain....damn it!!!!!!!
Old May 8, 2003 | 06:12 PM
Rodrigues's Avatar
http://static.howstuffworks.com/gif/camshaft-damage.jpg
Old May 8, 2003 | 06:13 PM
Z95m6's Avatar
probably should just plan on pulling the heads and that might give you an idea of the damage.
Old May 8, 2003 | 06:29 PM
marktisch's Avatar
If you back all the rockers off and give it a leak down test you will be able to tell of you bent valves.
Old May 8, 2003 | 06:38 PM
BOWTYDE's Avatar
WOW!
I think the best this to do it take the heads off, otherwise you can remove the rocker and the springs and check to see if any valves are bent but your never going to know about the pistons or the condition of the valve until you take the head off.
dbrockma
Feb 16, 2015 02:56 PM
sscott
Jan 17, 2015 04:30 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
1LEThumper
Jul 14, 2003 12:45 PM
