Okay, I need help with this...
The engine in my car was recently built, we tried to fire it for the first time and it ran for about 2 seconds then died. When I tried to restart it, it just cranked. Then, I notice gas leaking out of the end of the Y-pipe. If I wait a while, it will start again for just a second then die.
It looks as if I am getting to much fuel, the program is by PCMforless and was just loaded the other day. I don't believe it is the programming.
A new Walbro fuel pump was also installed the other day, it appears to be working fine. The Optispark is also brand new, as well as the harness.
Today I am going to get a scanner on it and try to pull DTCs, can I pull codes with the engine off?
I was also thinking of trying the stock program as well, will a stock program even work with the mods listed?
Any Ideas?
Any Ideas?
Re: Okay, I need help with this...
Any Ideas?
Any Ideas?
Magenta_Hearts
Mar 25, 2015 10:24 AM
slothgrant
15
Dec 11, 2003 10:40 PM
JasonD
Jul 15, 2002 02:17 PM
