okay I give up>>>
Old Oct 11, 2003 | 05:09 PM
F(ast)-body's Avatar
okay I give up>>>
how do you get the old U-joint out of the driveshaft....I've heated it (supposedly to weaken the injected nylon) put it in my vise as tight as I can....pryed on it, hammered it....I'm all out of options...how do you get the darn thing out????
Old Oct 11, 2003 | 06:01 PM
MattysTA's Avatar
did the nylon seep out? Cause you need to heat it up until it all seeps out. then hammer the **** out of it. I personally wnet and bought a mutipupose ball joint remover tool to press mine out. much easier....
Old Oct 11, 2003 | 06:03 PM
Z95m6's Avatar
i tried pressing mine out with the vise and it did nothing. I got the blacksmiths hammer and it came right out.
Old Oct 12, 2003 | 09:17 AM
what did you use to heat it up to the point that the nylon seeped out? I used a propane torch and it didn't budge! also, where to you get a "mulitpurpose ball joint remover" at???
Old Oct 12, 2003 | 12:32 PM
MattysTA's Avatar
I also used a propane torch, it takes like 5-10 minutes atleast to get them to heat up enough for the nylon to seep out. I got my multipurpose remover tool from a local autoparts store. costed me 90 bux but it can be used for many things and its worth it IMO.........
Old Oct 12, 2003 | 01:05 PM
Nomar's Avatar
I had to do that once on my old Formy...used an oxy-acetlene for about 5 minutes...sucker came right out with minimal hammering. I think you guys just need more heat.
football4life
Oct 4, 2015 07:48 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Sep 18, 2015 03:46 PM
