Ok, what cooling hose/metal line is this?
Ok, what cooling hose/metal line is this?(I think its oil cooler right?)
On the passenger side of the radiator, there is a large hose thats on the bottom...then right below that is a very skinny metal tube that goes to a hose, which goes back to a tube and goes somewhere under the car(right above the steering arm)
Looks like its an oil cooler line(http://csce.uark.edu/~jgbertr/rb/oil_cooler.jpg)
Looks like its number 17 that goes to number 11
I think this is where my leak is coming from. I put in some dye, and the dye is red...and this looks like a redish color coming out.
Thanks for any input, I hate cooling systems, I dont know much about them. This is a 95 BTW
heres one pic...its the 6 sided object..that tube inside of that..right below the big coolant line.
OK first off that line[11] is for the oil cooler
There is no '17' in the diagram[there is a clamp that is # 12?]
Do you have an oil cooler option?
Also the oil cooler [or bypass hose if no oil cooler] is on the DRIVERS side?
That 2nd pic.. it's hard to tell what it is a pic of.. it's too close in..
Are you sure it isn't automatic trans fluid[red] there are 2 approx 3/8" metal lines that are trans cooler lines..
I gotta get up under it again tomorrow and see if I can find any leaks...I found some fluid on a few hoses, but I think thats from earlier when I filled it up and spilt a few(it was on the hoses right under the fill hole)
Ill check it out tomorrow and see if I can find a leak..
Magenta_Hearts
Mar 25, 2015 10:24 AM
