OK to use gaskets that came with JET-HOTS?????
Old Jul 8, 2003 | 04:27 AM
CrippleFightin's Avatar
Just as it says...is it safe to use these or should I get different ones? Got any part numbers if I need new ones?
Old Jul 8, 2003 | 06:34 AM
SWINGRRR's Avatar
I been using them for awhile with no problems. If you get the copper ones make sure you dont get the D-port ones. They are too little and will get in the way of the header port causing a bottleneck.
Old Jul 8, 2003 | 07:48 AM
got_hp?'s Avatar
ive heard a few people blowing the ones that come with the headers..............i bought some felpros...........i heard mr.gasket's are good too.
Old Jul 8, 2003 | 08:12 AM
BitCypher's Avatar
I ordered a set of Fel-Pro 1406 gaskets and ARP 3/4" stainless header bolts to do mine.
Old Jul 8, 2003 | 10:57 AM
kmook's Avatar
Advanced Tech Moderator
The felpro 1406 are by far the best gasket ive used.
Old Jul 8, 2003 | 09:02 PM
D James's Avatar
well I used the ones supplied with the headers, since I am cheap and they have worked out very well fr me, its been over a year, Id say about 14 months and they still are fine, no signs of leaks. I of course have re-torqued those things down as tight as I could every so often. They came lose after two or three weeks, then a little less loose three or four weeks later, now they have remained tight since. Just make sure you go ahead and check them after a couple weeks, this should be done no matter what gasket you use, unless you go with locking bolts
Old Jul 8, 2003 | 09:35 PM
Timberwolf's Avatar
dammit...I ordered the felpro gaskets designed for the LT1... the 1470... are they going to burnout? Maybe I should open up the ports a bit to match the headers? I just didn't understand the huge oval port necessity when the heads have D ports...
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
pepon214tx
Sep 20, 2015 04:48 PM
