ok really!! best heads with cc306???
Old Jul 31, 2005 | 09:59 PM
red96z's Avatar
its almost time and want to make the best decision. i have searched but what makes the best power and produces the best track times. le ,afr ,....
Old Jul 31, 2005 | 10:03 PM
ulakovic22's Avatar
Re: ok really!! best heads with cc306???
If you are stroking the motor I would go with a set of Trick Flows or AFR's. Stock LT1 castings won't be able to flow as much as you will need. If you are swapping heads you could get a LT1 head max ported and should be fine. Just like everything else it depends on your goals and how big your wallet is.
Old Jul 31, 2005 | 10:09 PM
red96z's Avatar
no stroker yet but still want to make good numbers around 400rwhp. i was thinking le3 heads would be good but dont know enough about heads to make the decision alone. or go with lt4 casting and lt4 intake at the time of the swap if its worth the extra power ??? btw how much extra power going lt4?
Old Aug 1, 2005 | 01:00 PM
red96z's Avatar
come on what heads are making good numbers!!
Old Aug 1, 2005 | 01:43 PM
Crazy95Z's Avatar
If you want the most power, you need to match the cam to the heads, not the other way around. I would say go le3 and pick up his le3 cam. It had proven results. If you're wanting something a little cheaper, contact lloyd and tell him about your set-up so far and he can help you pick up the right heads.
Old Aug 1, 2005 | 09:48 PM
ulakovic22's Avatar
I think you could get the LE2 or LE3 heads and match them up with your 306 and be fine. I think that the 306 Llyod compares to his LE2 cam, so I'm sure you would be fine with either. Llyod is a great guy and he will point you in the right direction. Great customer service I don't know enough about the LT4 heads to say one way or the other, but I think I remember seeing that once both heads are ported they are pretty similar in flow, it's just out of the box the LT4 flow better. There's a website that gave flow numbers of a bunch of heads, it was malcams or something like that. If you search yahoo you can find it.
Old Aug 17, 2005 | 12:55 PM
roadtrip120's Avatar
check this out, LE1 heads with cc306
http://web.camaross.com/forums/showthread.php?t=390852
Old Aug 17, 2005 | 04:08 PM
buzz12586's Avatar
Was just about to point that out myself. He is making 400 hp with just LE1 heads which is pretty freaking sweet.
Victor Lamb
Aug 26, 2017 02:52 PM
StansZ28
Feb 19, 2015 07:39 AM
Roadie
Feb 16, 2015 10:34 AM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
