Ok to re-use gasket?
Old May 15, 2008 | 12:30 PM
94TEALz's Avatar
I had to pull the drivers side head off of the motor to install the oil galley plug that is half-way covered by the head since my engine builder decided not too. My question is can I reuse my fel-pro 1074 head gasket? The gasket has seriously been taken out of the wrapping slapped on with my heads and has been sitting on the engine stand for a month and thats it, when I pulled the head I checked the gasket and didnt see anything bad about it just leary because the head was torqued on.
Old May 15, 2008 | 12:32 PM
rickyzZ28's Avatar
I would not reuse the gasket, but it is your choice. Do you like taking the head off in the car if it leaks? They are pretty cheap so I would just get a new one.
Old May 15, 2008 | 12:45 PM
97sscamaross's Avatar
get a new gasket. it'll prevent possible head aches down the road
Old May 15, 2008 | 01:14 PM
11secgen's Avatar
you cant reuse headgaskets after theve been torqued,plus why take any chances your sig says a lil spray.just think how pissed youll be if it doesnt hold and you have to take it all apart again.these cars are such a pain to replace the headgasket.i take extra precautions on all of my cars. i used to use copper gaskets,o-rings and can of super 300,but now i just run cometics.
Old May 15, 2008 | 01:24 PM
cometics are good. All I ever plan on using is mls head gaskets. Can't beat them.
Old May 15, 2008 | 02:36 PM
rskrause's Avatar
Moderator
IF they don't leak. On a fresh build where you can specify the correct surface they are nice. Otherwise, there is about a 1/3 chance of seepage. As far as re-using the Fel Pro, no.
Rich
Old May 15, 2008 | 06:18 PM
user 647483's Avatar
Resuing head gaskets is a good way to end up doing the project all over again.
Grab a new one and sleep well knowing you did it right the first time.
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
pepon214tx
Sep 20, 2015 04:48 PM
