Ok pulling out hair time.
Old Apr 14, 2004 | 06:27 PM
1msfyter's Avatar
heres my problem my 97 Z28 keeps getting SES lights
I scanned it and it said 2 codes EGR sensor and Crank shaft position sensor.
Ive replaced the EGR valve, new crankshaft position sensor, new IAT sensor. STILL getting codes after clearing them.
plugs are new, wires all good and fit .
Cleaned TB , removed and clean IAC(gummed up)
Seafoamed,checked every wire we could find for breaks etc.
Anybody got any ideas?
Old Apr 14, 2004 | 07:12 PM
Larnach's Avatar
02 sensor?
Old Apr 14, 2004 | 07:15 PM
1msfyter's Avatar
wouldnt the scan say its an O2? I have a hand held scanner and all it says are those two egr and crank shaft positioner
Old Apr 14, 2004 | 08:52 PM
philcam01's Avatar
did you check for a 5v , and ground to them ??? just because you replaced the sensor and valve does not mean you fixed the problem.
Old Apr 14, 2004 | 09:15 PM
scoobysnax83's Avatar
thats what I was thinking....
Old Apr 14, 2004 | 09:30 PM
97WS6SCharged's Avatar
On the CPS, check the pigtail, they can become corroded and cause the computer to see it as a malfunction.
Victor Lamb
Aug 26, 2017 02:52 PM
Magenta_Hearts
Mar 29, 2017 08:54 PM
BLK1997Z28
May 7, 2015 03:01 PM
Snake Slayer
Jul 29, 2002 12:39 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
