Ok, my car is really pissing me off!
Old 03-10-2003, 08:38 PM
96Z28man's Avatar
Ok, overheating again. I changed the engine temp sensor, then it was ok for like a day. Now when I go from 1-3rd gear, my engine temp goes to like 260 and oil pressure is like almost 0!!! Then, when I go faster in 4-6th gear, the temp goes down to like 170ish, but still VERY low oil pressure. What the hell is the problem here, I honestly have no clue.
96Z28man is offline
Old 03-10-2003, 09:05 PM
RENE95Z's Avatar
Try bleeding any air that might be in your system, see if that helps the overheating problem.
RENE95Z is offline
Old 03-10-2003, 09:45 PM
scott95ta's Avatar
Maybe a head gasket. What is the oil pressure like before the trouble starts? How are the fluid levels? I would also check the fans to be sure they are coming on. That low oil pressure would worry me first I think. You caould also try removing the t-stat. Are you sure it is the correct one? I have heard that putting a "foward flow" t-stat in our cars will cause alot of trouble.
scott95ta is offline
Old 03-10-2003, 10:17 PM
kjlvilla's Avatar
Are you sure your oil pressure is near 0? If it is then you should hear your lifters clattering, especially off idle. How quickly does your temp gauge change? Do you hear detonation? An overheating engine should be spark knocking unless the pcm is really pulling the timing back, then it should really be sluggish. Maybe you have a problem with you instrument panel. Grounds? Powers? Good luck.
kjlvilla is offline
Jazsun
12-29-2014 12:14 PM
USAirman93
11-24-2014 03:37 PM
IgorT.455/406
06-04-2003 03:32 AM
JasonD
07-15-2002 02:17 PM
FASTFATBOY
06-20-2002 08:58 AM
Quick Reply: Ok, my car is really pissing me off!
