Ok, im finally gonna put my CC306 in, need some info on timing chain....
Old Nov 29, 2004 | 07:37 PM
Pasky's Avatar
Ok, I hear word of the Cloyes double roller but do I need a electric pump for it? Im basically looking for an alternative to the pricey LT4 ED timing set but if there is nothing out there better or just not worth doing to me, i'll get it. I don't want to switch to a eletric water pump, so are their any other timing sets I can use that can survive the CC306? Thanks.
Old Nov 29, 2004 | 07:39 PM
ibanez6rg's Avatar
Re: Ok, im finally gonna put my CC306 in, need some info on timing chain....
If you go with the Cloyes, you'll have to install an elec. W/P.
Old Nov 29, 2004 | 07:43 PM
dmoor88's Avatar
LT4 HD is one of your only options if you retain the stock waterpump. Ill be keeping mine when I install a cam so I think we're stuck.
Old Nov 29, 2004 | 07:50 PM
Pasky's Avatar
dayum, im trying to price out the cloyes and EWP and see if its cheaper than the lt4 ED, if so, i'll get that.
Old Nov 29, 2004 | 07:53 PM
dmoor88's Avatar
you can save a couple bucks by going with cmotorsports ex-187 double roller instead of the cloyes double roller.
Old Nov 29, 2004 | 08:04 PM
Pasky's Avatar
Just found my answer:
Jeg part numbers:
220-9-3145
171-6351
203 shipped, the pump is on sale.
Old Nov 30, 2004 | 10:27 AM
grygst76's Avatar
Jeg part numbers:
220-9-3145
171-6351
I used the lunati replacement, haven't had any problems yet...(knocks on wood)
Old Dec 3, 2004 | 11:54 PM
neversummer's Avatar
Why do I need EWP with a Cloyes true roller? Does the Cloyes not turn the waterpump gear?
Old Dec 4, 2004 | 03:23 AM
cmking26's Avatar
Im using this lunati from summit without problems. Its only $110.
http://store.summitracing.com/defaul...1+timing+chain
Old Dec 4, 2004 | 04:07 AM
1racerdude's Avatar
Cloyes makes the LT-4 ED for GM.Get it from Symmett and save a bunch of money.If you are going to run the factory water pump don't get the one with the oversize crank gear.Get the one to GM spect.
Old Dec 4, 2004 | 08:47 AM
BlackbirdWS6's Avatar
odd ball question, but my buddy is thinkin of just buying a new stock timing chain for his heads/cam(306). I'm sure it will work, but how long do u think it will last. I told him to just get the LT4 deal now but I was curious.
liamcg97
Nov 25, 2019 05:55 PM
bernie1951
Dec 10, 2014 10:03 AM
Snoman73
Nov 17, 2014 07:22 PM
CobraEatr
Jul 24, 2004 11:37 AM
The Big Show
Aug 12, 2002 04:50 PM
