ok Idle issue..nothing will help..
Old Aug 3, 2005 | 01:00 PM
Whitewolf's Avatar
this is what it isn't..
not the IAC..TPS..plugs..wires..opti..ECM..coil..ignition module..it has fuel..when it starts it runs fine as ;long as you give it a little throttle..ideas??
will not idle for more than 30 seconds without giving it throttle. also is hard to start back..
Brad
Old Aug 3, 2005 | 01:07 PM
SoloExceptional's Avatar
Re: ok Idle issue..nothing will help..
weak Fuel pump? Air filter? MAF sensor? Fuel filter? only so many other things it can be lol
You need a scanner to see what the IAC counts are. You say "not the IAC". Have you cleaned the passages?
Old Aug 3, 2005 | 01:11 PM
Whitewolf's Avatar
cleaned the passages and a new IAC and TPS.I have a air foil on the car. I even removed it. Same deal...it only does it at idle..and runs fine under throttle. The fuel pump is a aftermarket one..walbro 255 ..been in there for about 2 years..
Old Aug 3, 2005 | 01:13 PM
EKO's Avatar
EKO
[hijack]
Should the IAC plunger be movable by hand?
[/hijack]
Old Aug 3, 2005 | 01:16 PM
Weak Alternator/Battery? Bad Vacuum line? I'm just throwing things out there.
Old Aug 3, 2005 | 01:21 PM
marzen's Avatar
im gonna guess bad MAF.....maybe try running it disconnected and see if it still surges
Old Aug 3, 2005 | 01:22 PM
My car won't run with the MAF disconnected, it'll crank over then kill itself.
Old Aug 3, 2005 | 01:28 PM
EKO's Avatar
EKO
Bad MAF throws an SES too I believe. At least it does on some Fords.
Old Aug 3, 2005 | 01:29 PM
Originally Posted by EKO
[hijack]
[/hijack]
The pintle on a new one should be moveable (if carefully done). Manually moving the pintle on an old IAC is not recommended as you can more easily strip the gears.
Old Aug 3, 2005 | 01:30 PM
'94 Bad A Z28's Avatar
Brad
Sounds like the car is getting too much un-meetered air, check your intake elbow for any rips/tears/holes.
Old Aug 3, 2005 | 03:00 PM
Whitewolf's Avatar
my car runs does the same with the MAF dissconnected and connected so i dunno..could it be the MAP?
Brad
Old Aug 3, 2005 | 03:26 PM
ZMAN Z28's Avatar
Broken valve spring maybee
Z
Old Aug 3, 2005 | 03:30 PM
kevm14's Avatar
How is it not a calibration problem? It might just need another 75rpm of idle speed. Unless it was happily idling until, say, last week. Then I don't know.
Old Aug 3, 2005 | 03:39 PM
Whitewolf's Avatar
not a broken spring..car sounds and runs good under throttle. was idling fine..driving along..let off the throttle..wanted to die..give it some throttle ok..drove on..cruising speeds..fine..stopped in the driveway..let it idle..it died..did not want to start back..got it to start finally..will not idle more than a few seconds without throttle applyed...everything was ok...idle has been acting up a little..maybe a little ruff and maybe surging a few hundred rpms.but nothing major..now..won't idle at all. Nobody answered but could it be the MAP?
Brad
