ok... car making loud noise
Old Jul 17, 2005 | 02:20 PM
  #16
swemdog's Avatar
Re: ok... car making loud noise
that little rod is your valve stem
Old Jul 17, 2005 | 02:47 PM
  #17
1racerdude's Avatar
Originally Posted by white/blackss
That Little Sivler Post That U Say That U Can Move Up And Down By Hand, Thats The Valve. It Should Have Been Right At The Front Under The Rocker Arm, Dont Let It Fall Into The Head, You Might Have Gotten Lucky At This Point.
Theres A Tool To Put The Spring And Retainers Back On But You Will Have To Pull The Plenimun To Get At The Lifter. The Lifter Probably Isn`t Seated On The Cam Anymore.
Let Us Know How It Goes From Here.
1racerdude,,,, I Was Referring To The Rubber Valve Stem Seal That Sits Around The Valve Stem. I Have Seen Some Valves That Have The Spring Loaded Stem Seal And Also Another Large Rubber Boot In The Middle Of The Spring. Im Assuming That This Was Done To Help With The Oil From Getting On The Valve Stem Seal Itself. Sorry If I Was Wrong But Do You Know What Im Talking About??
Yea,the big seals that fit on the stem are called umbrella seals.Ford used them for years and Chevy too.The other type fit on the guide and are about the size of your third finder.
Didn't mean to make ya think ya was wrong,just maybe ya wasn't familiar with the top end all disassembled or torn up.
Old Jul 17, 2005 | 02:50 PM
  #18
Dave89IROC's Avatar
looks like you might be ok, I would pull the head to check the valve and piston though, the valve is probably bent after hitting the piston
with luck, all you need is gaskets, a valve, and keepers, I would pull the head and take it to a cylinder head shop
bfmv13trivium
Jan 14, 2015 09:57 AM
jj71787
Dec 30, 2014 02:15 PM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
