is this an ok cam
Old Feb 2, 2010 | 06:47 PM
red 95 z28 lt1's Avatar
is this an ok cam
hey guys just gettin my car back together and was just wondering what your thoughts were on this custom cam selection
240/240
.562/.562 w/ 1.6 rr
105 lsa
engine is a new 383 4 bolt main, stock ported heads to match the cam, 11.2:1 cr stock ignition, stock pcm but with a dyno tune when shes running, 42 lb injectors,
rest of mods in sig
will this car be considered driveable because i would like to take it out here and there from time to time.
car used to be a le2 383 setup and was daily driven for 3 years. just looking to see if anyone else has any experience with a similar set up
Old Feb 2, 2010 | 07:35 PM
Bersaglieri's Avatar
Looks like a stout and lopey camshaft, although you might want a little more stall to see the most out of it.
Hopefully the person who spec'ed that cam knows a helleva lot more than most of the folks on here.
-Dustin-
Old Feb 3, 2010 | 09:21 PM
red94chicken's Avatar
i have a 245/253 .612/.612 on a 107lsa in s 12.3:1 385 lt4.. are you sure that the 105 isnt the intake centerline? that is what mine is anyway. i am guessing that is an LE cam? anyway.. mine is pretty hairy but i can still drive it around. the only think that i would like different is its louder then ****.
http://s228.photobucket.com/albums/e...t=VID00058.flv
Old Mar 5, 2011 | 12:55 PM
Re: is this an ok cam
yea ive got the car running it seems to run rich, it wont idle when cold and i have alot of cam surge... has alot of power in the upper rpm though... im going to have my tuner go over everything and if i dont like it im gonna swap out the cam
Old Mar 5, 2011 | 09:46 PM
1slow93z28's Avatar
mind me asking who your using for a tuner? did you re-use your LE2 top end? is that a LE spec'd cam?
Old Mar 6, 2011 | 09:25 AM
it is not an le specd cam its supposed to be matched to the heads (stock ported still waiting on paper work on the heads) kaltech installed and tuned everything
Old Mar 6, 2011 | 10:08 AM
1slow93z28's Avatar
Brian is an excellent tuner. He tuned my cam only set up(he will be tuning my new set up soon) . Is the new heads/cam set up gonna outperform the LE2 set up by much? If the new cam was meant to perform best with the heads, then I don't see why a different cam is needed. You feel it should be bigger for a stroker?
Old Mar 6, 2011 | 10:19 AM
i know brian is an excelent tuner.. i however think the cam is to big for my car.. i do not know how much better it is over the le2 setup.. i daily drove my le2 383 for 3 years without much issues... i think the lsa should have been more like a 110... were gonna try more with the tune and take it from there... i also have a bunch of oil leaks that need to be adressed first
Old Mar 6, 2011 | 04:07 PM
1slow93z28's Avatar
What duty cycle are the injectors running at?
Old Mar 7, 2011 | 11:26 AM
i currently have 42lb hr injectors not sure if they are delph or lucas i dont know what the duty cycle is at the moment i would have to ask brian
Old Mar 8, 2011 | 09:39 PM
smog is not the issue here. my le2 cam was on a 110lsa and ran fine everyday
Old Mar 10, 2011 | 02:23 PM
ok... i have a little update... i read somewhere about adjusting the throttle blades so it gets more air at idle and slotting the tps or adjust for proper voltage... figured i would give it a try... cracked the blades open a little bit and adjusted the tps so it would read .68v at idle. started the car she started right up no foot on the gas to keep it from stalling out keep in mind the car hasent been started in about a week too. so im not getting that much cam surge right now but i havent driven it alot to notice... im just happier that i got it to idle cold without me holding my foot on the gas..
still have some bugs to work out and will get more info hopefully tommorow when the car goes back to the shop
Old Mar 10, 2011 | 02:45 PM
1slow93z28's Avatar
I was gonna suggest , but I didn't the other day to drill a hole in the tb flap for the idle issue
Old Mar 10, 2011 | 02:58 PM
a couple people sugested that now what is the difference between doing that and cracking the blades some with the idle screw and adjusting the tps... is one better then the other?
Old Mar 10, 2011 | 03:40 PM
1slow93z28's Avatar
Both methods achieve the same thing, so honeslty, I don't know the advantages of one method over the other... hopefully somebody can chime in as I'm also interested to know.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
