Oil Temperature Sensor Location
Old Dec 26, 2008 | 06:09 AM
95Blackhawk's Avatar
Where do people generally put this?
Old Dec 26, 2008 | 08:07 AM
Ken95Z28's Avatar
Mine is right above the oil filter, there is a port there that you can use where the oil filter screws into.
Old Dec 26, 2008 | 09:05 AM
maverickmk's Avatar
oil temp or oil pressure? temp is in the pan - pressure is either beside the filter location as said above or behind the intake
Old Dec 26, 2008 | 09:18 AM
I drilled and tapped the oil drain plug, screwed in a temp sensor. Put a connector in the wire so you can unplug it to drain the oil.
Old Dec 26, 2008 | 03:32 PM
Temperature. Where in the pan would you put it?
I personally like Injuneer's suggestion and will probably go with it.
Old Dec 26, 2008 | 08:40 PM
maverickmk's Avatar
You can fit it like Fred suggested, or if you have the pan off you can weld one of these in . . . http://store.summitracing.com/partde...?part=ATM-2261
Old Dec 27, 2008 | 08:42 AM
sbs's Avatar
sbs
GM put mine above the oil filter.
HectorM52
Jul 30, 2017 11:46 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Jazsun
Dec 29, 2014 12:14 PM
