Oil Temperature Sensor location
Old Jul 19, 2004 | 08:04 PM
Miamispd's Avatar
Where is the preferable location to place an oil temp. sensor. I am running an oil cooler with an accumulator pump.
Old Jul 19, 2004 | 08:14 PM
carlos64030's Avatar
Re: Oil Temperature Sensor location
I'd say on the side of the oil pan.
Old Jul 20, 2004 | 04:34 PM
To avoid drilling the pan, I drilled and tapped the drain plug, so the sensor will screw into it. Simply requires a "connector" so the wire can be disconnected for an oil change.
http://cjcfo.fbody.com/members/injun...J/DCP02758.jpg
Old Jul 21, 2004 | 07:40 AM
Miamispd's Avatar
The pan is a good idea. I guess you lose the magnetic plug.
Old Jul 21, 2004 | 11:30 AM
JohnD's Avatar
There is a plug in the block above the oil filter that is 3/8 x 27 thread. With an adaptor an oil temp sensor will screw in there. In my case because of the dual cats, it is really hot right there and I had to insulate the sensor to keep it from giving a false reading.
Old Jul 21, 2004 | 04:26 PM
I suspect that's where he already has his accumlator connected.
HectorM52
Jul 30, 2017 11:46 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Jazsun
Dec 29, 2014 12:14 PM
