Oil Temperature Sensor location
Re: Oil Temperature Sensor location
To avoid drilling the pan, I drilled and tapped the drain plug, so the sensor will screw into it. Simply requires a "connector" so the wire can be disconnected for an oil change.
http://cjcfo.fbody.com/members/injun...J/DCP02758.jpg
There is a plug in the block above the oil filter that is 3/8 x 27 thread. With an adaptor an oil temp sensor will screw in there. In my case because of the dual cats, it is really hot right there and I had to insulate the sensor to keep it from giving a false reading.
