Oil sender? Cluster? what is the prob?
Old Dec 28, 2003 | 02:48 AM
JThunderZ28's Avatar
ok after i had my engine rebuilt i noticed the oil pressure gauge was stuck. It is jammed all the way to the left like its maxed out. im wondering if its the sender or if its the entire cluster that i have to replace?
oh and is there a way to read oil pressure in the mean while so i at least have an idea of what the pressure is?
Old Dec 28, 2003 | 03:04 AM
97WS6SCharged's Avatar
It's probably just the sender or a loose wire. Not too many other options to check oil pressure, unless you want to put in an aftermarket gauge in a pillar pod or something. Just fix the sender/wire and you should be fine.
Old Dec 28, 2003 | 06:57 AM
Seal's Avatar
they forgot to plug it in...
its right behind the intake manifold on the left side towards EGR thingy :P
when its not plugged in, or the unit is faulty, it will go all the way to max.... thats how mine is right now.... the thing is at such a place that i can grip it, but i cant twist my hand to get it out errrrr
so its stuck like that.... i put a new one in (just plugged the wire) and the sender went to 0 like it should...
so yeah anyways
they most likely forgot to plug it in
Old Dec 28, 2003 | 10:29 PM
thx for the help. but the dealer i took it to just said to buy a new cluster? are they trying to rape me for labor and parts? i suspect that.
Old Dec 28, 2003 | 11:10 PM
97Z-pimp's Avatar
no man dont buy a new cluster, after you hook up the sending unit right the oil pressure should read on the guage. The same thing happened to me and it was just a bad wire comming out of the unit. Goodluck
Old Jan 2, 2004 | 07:01 PM
Tony Danza's Avatar
how much would a new cluster cost? and how much would the labor be for it?
Old Jan 2, 2004 | 08:25 PM
mtxpert's Avatar
Sorry to hijack thread but I have the same problem but with Z28 cluster in 96 Impala.
Anybody know the color of the wire off of the oil pressure sender that is pressure? My DMM is broken.
Mike
Old Jan 2, 2004 | 08:36 PM
matt diamond's Avatar
Mike
according to alldata it is tan
hope that helps.
Old Jan 2, 2004 | 08:42 PM
mike, call me at the shop in the morning 480-497-8811. there is a way to test if the sender is bad or if it is something else.
Old Jan 2, 2004 | 09:39 PM
mtxpert's Avatar
Thanks Matt!
Mike
Old Jan 3, 2004 | 02:04 AM
Tony Danza's Avatar
Old Jan 3, 2004 | 02:27 AM
mtxpert's Avatar
Mine is now fixed, the wire required for this wasn't installed on my custom wiring harness for 96 Impala to Z28 cluster.
A little soldering and it's all good.
Now I have to change the sender so that the pressure gauge is more accurate.
Mike
Old Jan 3, 2004 | 05:59 PM
don't pay anyone to do it. it does not take that long to take the dash apart. i have done it quite a few times.
the cheapest place to look for a cluster is ebay or a junk yard.
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Aug 4, 2015 01:54 PM
Jul 4, 2005 05:00 PM
asianice25
Aug 16, 2002 09:31 AM
asianice25
Jun 13, 2002 02:01 PM
