oil seals touching the valve springs
Old Feb 28, 2005 | 10:25 PM
92rslt1's Avatar
i have dual valve spring comp brand and it seems like my oil seals on the guides are touching the inner spring. this doesnt seem normal but i dont see were i could find a smaller seal. any suggestions??
Old Mar 1, 2005 | 07:21 AM
mohawkmike's Avatar
Re: oil seals touching the valve springs
youll probably have to have the guides cut for smaller seals.
Old Mar 13, 2005 | 11:54 PM
92rslt1's Avatar
any other suggestions? im sure not eeveryone who runs dual springs has to hae guides cut.
Old Mar 14, 2005 | 02:02 AM
Spinner's Avatar
My comp 985s clear my GM seals. The GMs are the smallest out there AFAIK that fit on the stock guide
Old Mar 14, 2005 | 02:19 AM
sssalah's Avatar
What specific springs are you using? I've used both 986 and 987 with the stock seal and they clear fine. The older rubber seals are bigger and they will hit, is it possible that you're running with those.
Old Mar 14, 2005 | 05:55 PM
92rslt1's Avatar
i suppose its possible they are black seals with a spring around them other than that im not sure. im running 985's.
Old Mar 14, 2005 | 07:49 PM
Spinner's Avatar
Then the GM seals should clear. Mine do.
DirtyDaveW
Mar 15, 2015 07:01 PM
Roadie
Feb 16, 2015 10:34 AM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
