Oil pump pickup tube
Old Jun 19, 2004 | 12:45 PM
southern78's Avatar
I put in a new oil pump and am going to reuse the old pickup tube. It fits in the new pump fine just not as snug as it was in old one. It will not stay up right. Is this normal or is there a way to get it to stick in firmly?
Old Jun 19, 2004 | 02:15 PM
BadAssed93Z's Avatar
a spot weld will hold it
thats what will be holding mine in.
Old Jun 19, 2004 | 02:38 PM
schpenxel's Avatar
yea weld it on...you may regret any other way
Old Jun 19, 2004 | 03:15 PM
Fastbird93's Avatar
Here's another vote for a tack weld to hold it on.
Old Jun 19, 2004 | 03:17 PM
southern78's Avatar
Well shoot fellows I dont have a welder
Old Jun 19, 2004 | 03:45 PM
schpenxel's Avatar
Find a friend that does, or stop by a machine shop...they should be able to do it in about 5 seconds and not charge you much if anything...
Old Jun 19, 2004 | 10:12 PM
Re: Oil pump pickup tube
One reason to get a new pickup.
Old Jun 20, 2004 | 10:14 AM
arnie's Avatar
I'd check/compare the hole size of previous and present pickup tube hole in covers, to verify new pump does not have a larger hole. Pointless to get a new tube of the same diameter.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Jul 4, 2005 05:00 PM
