Oil pump drive won't go in
Old Nov 11, 2007 | 01:10 PM
95z28man's Avatar
Just installed a new cam, my oil pump drive won't sit back in place flush with the bolt hole. I'm hoping this doesn't mean somethings up with the cam.
Old Nov 11, 2007 | 01:24 PM
wrd1972's Avatar
It is just very tricky to do due to the helical gears plus having to line up the drive shaft.
Take a break, chug a beer and try again.
Old Nov 11, 2007 | 01:25 PM
WS6T3RROR's Avatar
Turn the oil pump drive shaft a little and try again, thats what you're hitting, its just a trial and error process, dont sweat it. Try to keep the gear that meshes with the cam in the same position all the time so you're not chasing your tail.
Old Nov 11, 2007 | 01:58 PM
95z28man's Avatar
Problem solved. Thanks
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
