Oil pump drive sheered today :D
Old Feb 2, 2008 | 04:38 PM
jay_rich's Avatar
Well I was tunning my car (tranny) and on the last pull I backed aff and as soon as i did i started to looks pressure. Luckily i was pullinf into my buddies driveway. So i pulled the vavle cover and no oil was comming up.
I ended up pulling the intake and checking the oil pump drive and sure enough there is only 4 teeth on it and there messed up too.
Where will the peices go to after they break? Should i pull the pan and change the pump also. I am gonna manually crank the motor to check the cam and see if its fine.
I beleive i have a 95 motor in my car (87 iroc lt1 swap). Is there a difference between 94-95 oil pump drives?
Also What should i replace it with? Now would probably be a good time to do a cam BUT i dont feel like spending another 800ish on a cam and springs when i may need a tranny build.
I will post pics tonite showing it.
UPDATE
Old Feb 2, 2008 | 05:53 PM
Just curious as to what oil pump you are currently running...
Old Feb 2, 2008 | 06:28 PM
LT4Camaro's Avatar
i went thru 5 of them in 2 years , i just got rid of the Melling high volume pump and put a standard volume high pressure pump. Gonn a start it up tomorrow see what happens, i know for a fact it was the oil pump cuz everytime i sheared one off i changed the whole assembly with a new one, then the last time i even replaced the camshaft and a whole new assembly for the oil drive, and still ripped it apart after a few months.
I dont understand why i cant use a high volume pump but oh well.
Old Feb 2, 2008 | 09:02 PM
maverickmk's Avatar
'93 - '95 LT1 oil pump drive GM PN 1103868
Old Feb 2, 2008 | 09:18 PM
jay_rich's Avatar
Well I decided Im gonna buy a crap load of crappy oil and keep pouring to try to flush out the motor. And buy a few filters and change them out a bunch of times to try to get everything outta the motor. I wanted to do a cam swap etc, but I dont feel like spending more money right now.
So im crossing my fingers that all goes well!!!!!
The pump i am not sure the motor was professionally build prior to me getting it.
Jay
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
StngStlkr
Sep 6, 2002 05:47 PM
