Oil pump drive geat???
Old May 29, 2006 | 05:12 PM
Heatmaker's Avatar
Advanced Member
I just brought some new goodies for the car, and I feel pretty good now about it, but I think there is one thing I'm forgetting. On the back of the lifter valley there is a a plastic something or another you have to remove to install the cam. I don't remember what it's called right now becasue I have a bad headache, but it deals with the oil pump drive gear on the cam. It's made of plasic, and I've known of guys who had these things break on em after a cam swap. Does anyone know who sells metal replacement piece? if there is such a thing?
Old May 29, 2006 | 05:20 PM
1racerdude's Avatar
Re: Oil pump drive geat???
There is no metal replacement. More preformance sells a metal safty to keep it from jumping out of the hole($20.00).
I have had the machine shop duplicate the plastic piece with an aluminum piece(pricey)
Old May 29, 2006 | 05:33 PM
Heatmaker's Avatar
Advanced Member
something tells me I should buy a new one.
Old May 29, 2006 | 05:54 PM
jmzlt1's Avatar
At best you should buy a new one. More performance went out of business, so you will have to look elsewhere for oil pressure saver bracket. I would get a bracket too, just in case. It could save you a motor if the part breaks and stops running you're oil pump
Old May 30, 2006 | 05:49 AM
Heatmaker's Avatar
Advanced Member
anyone know the part numbers off hand?
Old May 30, 2006 | 07:26 AM
Javier97Z28's Avatar
Moderator
Part #1103868 is the oil pump drive.
Yes, I'd replace it.
And as mentioned, More Perf. is out of business. Sucks b/c I wanted to buy the metal retainer as well.
Old May 30, 2006 | 10:36 AM
Heatmaker's Avatar
Advanced Member
Thanks much appreciated
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
