Oil pump drive gear question
Old Sep 10, 2008 | 10:54 AM
cause4panic's Avatar
So I have to pull my intake because of a leak. The motor has approx 140k on the clock and will most likely be rebuilt within a year or two. Should I disturb the oil pump drive gear or leave it be? The oil pressure is good, 60 psi cold and 18 psi fully hot read from the port behind the intake manifold slightly over 20 psi of oil pressure at the port right above the filter.
Thank you
BB
Old Sep 10, 2008 | 04:10 PM
You could pull it out and look at it to see if it is worn. That might help you decide.
Old Sep 11, 2008 | 11:53 AM
Connexion2005's Avatar
Like Shoe said. Pull it out and check for excessive wear on any of the teeth. Get your head back there and look at the cam gear as well for wear. It will only take a minute or two to make sure.
Old Sep 11, 2008 | 12:01 PM
I hope i dont crack that plastic pos, maybe its just the hv pumps breaking them. its 13 ft lbs correct?
Old Sep 11, 2008 | 03:35 PM
Yes.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
pologreen97z
Dec 2, 2014 10:42 AM
Jul 4, 2005 05:00 PM
