Oil pump drive gear, missing teeth
Old Jun 29, 2005 | 12:10 AM
roadtrip120's Avatar
My car lost oil pressure yesterday in the middle of a run. After pulling the pan and intake i found out that the oil pump distributor gear was missing 5-6 teeth!!! The gear looks like it was about to let go, all of the remaining teeth are thin and sharp. I have heard about running a bronze gear on aftermarket cams, but mine is stock, what gives?? I do have a high volume oil pump, its been in the car for about a year now. Last time i looked at the oil drive gear, it looked ok.
Why did the gear wear out??
High volume pump-- 138,000 miles(old age)--- something else is wrong
Old Jun 29, 2005 | 12:59 AM
MaxLean's Avatar
Re: Oil pump drive gear, missing teeth
Same thing happened to me. I reinstalled my old oil pump drive (which looked good despite having 40k miles on it and had seen at least three different cams), in my new 383 with a new comp cams cam with iron gear I believe. Well, after about 2k miles, I lost oil pressure pulling out of the driveway. Took the intake off and sure enough 5 teeth were missing and the others were paper thin. The cam gear looked good, so I risked it and installed a new drive gear. It's been 7k miles later and so far so good!
Old Jun 29, 2005 | 08:19 AM
High volume pumps put more stress on the gear. The pump is naturally harder to turn because of the larger gears required for more volume.
Old Jul 4, 2005 | 12:31 PM
95Zedder's Avatar
The same thing happened to me last week. Is there any stronger gear that we can use or do you just buy a new OEM part?
Old Jul 4, 2005 | 05:07 PM
MaxLean's Avatar
I looked all over the place and couldn't find anything other than OEM, and then you have to buy the whole assy. You can't just use a standard SBC gear as the shaft diameter is different. Standard SBC is .491" and the LT1 oil pump drive uses something like a .450" (can't be sure, but is definitely smaller).
Old Jul 5, 2005 | 02:24 AM
.427
Crane CRN-11988-1
Summit has a bronze gear for 39.99, not sure if you can run in on a lt1 or not. I know some cams require you to run a bronze gear, not sure about stock. But i am running it on my car has we speek, i've got about 200 miles on it. I bought it after i posted this thread. I think the bronze is stronger or it doesn't wear against a certain metal.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Elcojoe
Nov 17, 2014 10:27 PM
