Oil Pump blew, And im happy!
Old Aug 2, 2004 | 10:17 PM
Briank8811's Avatar
Ok sounds weird right? Well this all started with a stroker in mind. Well i had the engine built under warranty before i knew much about cams. I put a freakin HOTCAM in a 383. I know I know its small. Well during the 3rd warm up session once the motor was installed it lost all oil pressure. Well it turns out the link that runs the oil pump off the cam chewed up the cam gear. Well the motor was shut down right away and i had the motor broken down today. Turns out all is good with everything other than the cam which is a lucky draw for me. Well since it blew the oil pump i get a certain ammount of money to fix it.....And it turns out to be enough for all the required oil pump purchases and labor AND the shop has agreed to hook me up with a CC306 for free beacuse of the delay! Yea im freakin happy! Well all the MODS are in my sig but scratch the HOTCAM and ADD a CC306. Now what could i expect HP wise with this different cam? People said i would be lucky to get 360 RWHP with the HOTCAM and about 400 Hp at the crank. Now what could i expect? By the way i am getting it dyno tuned. Thanks for any replys
Old Aug 2, 2004 | 10:31 PM
Spinner's Avatar
Re: Oil Pump blew, And im happy!
Not much more without ported heads and craptastic headers on a big cube motor
Old Aug 2, 2004 | 11:20 PM
1racerdude's Avatar
Ya need head's dude.Big heads=AFR 227 FULL PORTED OR LARGER.
Old Aug 2, 2004 | 11:23 PM
Briank8811's Avatar
Hey well its gotta be better than the hotcam. If i had money to feed tons of gas to it and buy the thousands of dollars in heads and headders then i would, but for being 16 i think it will scoot pretty good.
Old Aug 2, 2004 | 11:26 PM
1racerdude's Avatar
To a point!!!And ya still need heads.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
