oil pressure sensor (93 lt1) touching header
Old 05-23-2014, 10:26 PM
sgtjet's Avatar
I installed my Pacesetter Long tubes but now my oil pressure sensor is touching the header. Will the sensor be ok if I can put the boot over the sensor?
sgtjet is offline
Old 05-24-2014, 09:45 AM
Re: oil pressure sensor (93 lt1) touching header
You could move the oil pressure sensor to the top/rear of the block, where it is located on all the LT1's except the 93 and very early 94 models.
http://shbox.com/1/op_sensor.jpg
Alternatively, look at adding an angle fitting to move the sensor away from the headers.
All that heat can't be good for it.
Injuneer is online now
HectorM52
07-30-2017 11:46 AM
phoenix95
01-08-2015 02:44 PM
phoenix95
01-08-2015 09:14 AM
Jessie4tin
01-07-2015 08:53 AM
07-04-2005 05:00 PM
Quick Reply: oil pressure sensor (93 lt1) touching header
