oil pressure sensor (93 lt1) touching header
Old May 23, 2014 | 10:26 PM
sgtjet's Avatar
I installed my Pacesetter Long tubes but now my oil pressure sensor is touching the header. Will the sensor be ok if I can put the boot over the sensor?
Old May 24, 2014 | 09:45 AM
Re: oil pressure sensor (93 lt1) touching header
You could move the oil pressure sensor to the top/rear of the block, where it is located on all the LT1's except the 93 and very early 94 models.
http://shbox.com/1/op_sensor.jpg
Alternatively, look at adding an angle fitting to move the sensor away from the headers.
All that heat can't be good for it.
HectorM52
Jul 30, 2017 11:46 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
