Oil pressure sending unit, broke with header install...
Old Aug 11, 2004 | 06:59 AM
NVetro's Avatar
Hey all...my oil pressure is reading 0. I broke the unit on the back of the intake manifold (oil pressure sending unit) when I we were tilting the motor for my headers. I am trying to find out what I need, Shoebox? Does anyone know the part number of the item that everyone breaks when they do the header install?
Old Aug 11, 2004 | 07:00 AM
Fastbird93's Avatar
Re: Oil pressure sending unit, broke with header install...
Can't tell you the part number, but pretty much any parts store should have it in stock. All you need is the sending unit, it's basically a metal threaded end with a plastic wiring harness receiver attached to the back, which is what usually breaks off. Real simple fix.
Old Aug 11, 2004 | 07:03 AM
NVetro's Avatar
Thanks for the fast reply! Anyone have the part number of this unit? I assume I need the whole thing.
Old Aug 11, 2004 | 07:29 AM
The p/n is listed on my Part Numbers page. You can also get one from an auto parts store. It's all one piece, so you need the whole thing. It's only 2 pieces when you break it.
Old Aug 11, 2004 | 07:40 AM
NVetro's Avatar
Shoebox, thanks alot. Which one do I need? 24575127 or 10201491. Also do I need the angle fittings? or does the sensor screw into the fittings? Thanks.
Old Aug 11, 2004 | 11:01 AM
You need the 10201491 since it is in back of the manifold. You don't need to replace the angle fittings. I'll put a clarification on the sensor locations on the part number page.
Old Aug 11, 2004 | 11:27 AM
95RagtopTA's Avatar
I just had to replace mine (broke during head install). Dealer quoted me $48--ended up getting it from NAPA for only $23......
Old Aug 11, 2004 | 12:21 PM
HardcoreRM125's Avatar
Damn ... Mine wasnt even on the car when I got it since it was totaled and the engine was pulled. I spent 50$ on the ****er from a dealership cause I never thought NAPA would have on, Owell
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
transam_388
Mar 15, 2015 11:53 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Jul 4, 2005 05:00 PM
