Oil pressure sending unit, broke with header install...
Hey all...my oil pressure is reading 0. I broke the unit on the back of the intake manifold (oil pressure sending unit) when I we were tilting the motor for my headers. I am trying to find out what I need, Shoebox? Does anyone know the part number of the item that everyone breaks when they do the header install?
Re: Oil pressure sending unit, broke with header install...
Can't tell you the part number, but pretty much any parts store should have it in stock. All you need is the sending unit, it's basically a metal threaded end with a plastic wiring harness receiver attached to the back, which is what usually breaks off. Real simple fix.
The p/n is listed on my Part Numbers page. You can also get one from an auto parts store. It's all one piece, so you need the whole thing. It's only 2 pieces when you break it.
Shoebox, thanks alot. Which one do I need? 24575127 or 10201491. Also do I need the angle fittings? or does the sensor screw into the fittings? Thanks.
Damn ... Mine wasnt even on the car when I got it since it was totaled and the engine was pulled. I spent 50$ on the ****er from a dealership cause I never thought NAPA would have on, Owell
Jul 4, 2005 05:00 PM
