Oil pressure sender removal question
Old May 24, 2007 | 07:22 PM
976speed's Avatar
Do i have to take my intake off to replace my oil pressure sender or is it possible to do it with the intake on??
Old May 24, 2007 | 07:29 PM
mobleman's Avatar
I've replaced it without removing the intake. Just takes some long arms and patience.. Also a a special socket helps, I think you can rent one from autozone.
Old May 24, 2007 | 08:11 PM
Use the special oil pressure sensor socket. With an extension, aim from the brake booster toward the sensor, along the firewall.
Old May 24, 2007 | 08:33 PM
BMAN'S SCZ's Avatar
Five minutes with the special socket. I think it is 1-1/16 Dia. and 2-3/4 deep. I think I got mine at AutoZone for like $6.When you find one ask to see the sending unit to make sure it fits. I went to one place and they said it would work but when I tried it, their socket was to short. Good luck......John
Old May 25, 2007 | 09:18 AM
OBE1 95Z28's Avatar
Shoebox has a good photo of the sensor here: http://shbox.com/1/oil_pressure_sensor.jpg
Old May 25, 2007 | 09:34 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
Is the special socket necessary? I'm going to be replacing this sensor next week, but I'll also be taking off my intake to fix an oil leak.
Old May 25, 2007 | 09:48 AM
JP95ZM6's Avatar
I tried it without the special socket, and couldn't. Any wrench big enough to get on the sensor had too little room to turn. I decided to remove the sensor as I pulled the motor so I'd have more clearance. But I broke it off in the process.
Save yourself some hassle and get the socket!
Old May 25, 2007 | 11:08 AM
It is pretty much necessary. The sensor has rounded shoulders that do not allow a 12 pt socket to fit. A deep enough 6 pt socket might work.
HectorM52
Jul 30, 2017 11:46 AM
Z28countrymama
Jan 22, 2015 02:50 AM
phoenix95
Jan 8, 2015 02:44 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
