oil pressure sender
Old Dec 15, 2015 | 06:08 PM
frankrizz's Avatar
oil pressure sender
Hey Gentlemen,
Is there any other location other than the back of the
intake that I can install an aftermarket AutoMeter oil pressure sending unit?
Old Dec 15, 2015 | 09:00 PM
Re: oil pressure sender
Pressure port right above the oil filter. That is where the sensor is located on 93 and "early" 94's. May need an adapter, depending on the diameter of the Autometer sensor. I have a mechanical gauge, with a braided S/S line screwed into that port.
The pressure port on a late 94 and up is actually on the top edge of the block, not the manifold.
Shoebox has photos on shbox.com
Old Dec 15, 2015 | 10:23 PM
Old Dec 16, 2015 | 05:11 AM
frankrizz's Avatar
Thank You! I will check it out.
KYWes
Dec 18, 2015 09:34 PM
frankrizz
Nov 21, 2015 05:50 AM
IDriveA95Z28
Nov 20, 2015 12:57 PM
Shuvl82
Nov 18, 2015 12:03 PM
