Oil Pressure Question
Old Oct 15, 2016 | 07:00 AM
sscott's Avatar
Hello, I have a '97 Camaro SS and have a question about my oil pressure, when I fire up the car the oil pressure reads about 70 psi and when under load it reads above 40 psi about 42/43. Now at idle or sitting at a light it drops to above 20 psi and fluctuates up and down between 20 and 30, when I accelerate it's holding steady above 40 psi constantly with no drop, it only drops at idle. Is this something to worry about? I'm using Amsoil Zrod 10w-30. Thanks for your time and efforts towards this question.
Old Oct 15, 2016 | 07:26 AM
Re: Oil Pressure Question
That's pretty normal operation and pressures look fine. Pressure is higher when the engine is cold and oil is thicker.
Old Oct 15, 2016 | 07:49 AM
sscott's Avatar
Thanks shoebox!
Old Oct 15, 2016 | 11:14 PM
JakeRobb's Avatar
Super Moderator
Does Amsoil Zrod include a ZDDP additive? If so, no need for that with your LT1's roller cam.
walt355
Mar 16, 2016 09:35 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Double aught
Oct 2, 2015 11:29 PM
tdigger9899
Sep 7, 2015 10:56 AM
dmaastr
9
Jul 1, 2002 02:22 PM
