Oil pressure question
Old Feb 26, 2003 | 06:40 PM
chevroletfreak's Avatar
Is it normal for the oil pressure to flux at a STEADY high rate of speed (approx. 120 MPH & 2500 RPM)? Mine will flux about 15 PSI.
If it is not, does this necessitate a higher volume or pressure pump? What else can be done?
Old Feb 28, 2003 | 08:58 AM
anyone????
Old Feb 28, 2003 | 09:00 AM
Smoke T/A's Avatar
The rule of thumb I go buy is 10psi for every 1000 rpm. HTH
Joe
Old Feb 28, 2003 | 09:07 AM
Rodrigues's Avatar
10 psi for every 1500 rpm is fine...
Old Feb 28, 2003 | 10:27 AM
mebanditws6's Avatar
Replace your sending unit first before you do anything else. The stock one is crap if it flucutates. 15psi at 2500 isn't good. Any good conditioned LT1 at 600 rpm idle gets at least that much.
Jason
Old Feb 28, 2003 | 10:55 AM
drop top steve's Avatar
Re: Oil pressure question
Your oil pressure should not fluctuate at steady rpm. At 2500 rpm it should rock steady, vehicile speed should not effect it. May be bad sender or gauge. Check your oil level??
Old Mar 1, 2003 | 06:33 PM
Oil level is good.
mebanditws6 - 15PSI is how much it was fluctuating. I think the pressre was about 65 or so and then it fluctuated about 15 PSI from there.
Any other ideas? I wouldnt think it is the sending unit because it is fairly new (about 10,000 miles) and this was the only time it fluctuates at a steady RPM. At any other time it doesnt fluctuated. Even at a steady 2500 RPM in slower speeds.
Old Mar 3, 2003 | 11:15 PM
Oil level is good.
Uh oh sounds like a sludge problem. Get some of this stuff www.auto-rx.com I just started a treatment of it in my Jeep. I think though if the motor is a high mileage motor it'd be a good idea to drop the pan and replace the oil pump as well. My Jeep did this, and sludge was the exact cause. The pan was cleaned as well as a new oil pump was put on, but I'm still running this rx stuff to clean out the top end of the engine. The direct cause is a clogged pickup screen, but the rest of the engine is probably pretty dirty as well and could use a couple rx treatments.
Jason
Old Mar 4, 2003 | 12:30 AM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
How the heck were you going 120 at only 2500 rpm's?
Old Mar 4, 2003 | 09:22 PM
mebanditws6
I am pretty sure it is not a sludge problem because I replaced the oil pan about 10K ago. It wasnt too bad when I pulled it ouff. I also ensured the pick-up was cleaned off before I put the pan back in. Now I wish I would have changed the pump also.
95z28 -quicksilver
Ok, so I lied..........It is about 2550 RPM at 120MPH.
The reason is because I have a 93 that originally came with an M29 and 3.23's. I replaced the tranny with a brand new 94+ style with the .50 6th instead of the stock .62 6th. I have yet to get rid of the lowly 3.23's though. I do not even use 6th gear until 90 MPH. I wish I had the room and the cohones to top it out . When I go to the track I croos the line at the end of 3rd gear!
Old Mar 5, 2003 | 12:25 AM
Hmmm well I guess you ought to hook up a mechanical guage to see exactly what the pressure is. Either way though I'd still recommend auto-rx cause at least the top part of the engine could might be a bit dirty. Plus it's great preventative maintenance. If the mechanical guage checks in with good results you just need to replace the sending unit again as it may have busted. If the mechanical guage reports fluctuations then the oil pump would be prime suspect.
You really need to get a different rear in there. To be in 3rd at the end of a race is just not right . I think 3.73's would do you fine. 4.10's might and do seem to work well with the 6spds, but first gear would be almost useless.
Jason
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
