OIL Pressure Question
Old Jul 18, 2005 | 10:51 PM
ZU_LTR's Avatar
Question OIL Pressure Question
I noticed that when i first start my car in the morning the oil pressure is around 40psi then once it warms up it drops to around 20psi . it goes up to 40psi when i'm driving but then when i come to a stop it drops back to 20psi at idle.
is that normal for a 95 camaro LT1. and if not what would the problem be.
any help is appreciated....
Old Jul 18, 2005 | 11:04 PM
2000LS1Z28's Avatar
Re: OIL Pressure Question
That is perfectly normal for your car...My '95 Z28 also settles in nicely at 20psi during a hot idle and quickly jumps up to 40ish between 1500-2000rpms at normal operating temps...
Although my car's oil pressure is a good 55 or so during a cold start after sitting all night...
Your car is fine bro,
Mike
FastZinTennessee's Avatar
Sounds fine to me.
Old Jul 18, 2005 | 11:09 PM
93LT1355's Avatar
oil is thicker when it is cold so you will get better pressure when you first start the engine up, but you numbers look fine.
Old Jul 18, 2005 | 11:10 PM
ZU_LTR's Avatar
thanks guys i thought it was ok, but better safe than sorry . I just bought the car 3 days ago and just wanted to be sure. my oil pressure is above 40psi when i start the car some times it's around 55-60psi so that's good to know ..
My 1995 Camaro Z28
Old Jul 18, 2005 | 11:24 PM
RedLT4Mike's Avatar
You've got the right idea with the "Better safe than sorry" attitude
I just wanted to use this smiley!
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
