How do you replace knock sensor wire and PCM ground?
Old Jul 18, 2005 | 04:48 PM
94TA25ann's Avatar
The wire for my PCM ground is faulty and so is the wire that runs to the knock sensor. I was wondering how to get the wire out of the connector that attaches on to the sensor. Also how do you get it out of the connector on the back of the PCM. I was trying to figure it out today, but was having a hard time and eventually ran out out of time before going to work.
Thnaks,
Jon
Old Jul 18, 2005 | 06:54 PM
ZMAN Z28's Avatar
Re: How do you replace knock sensor wire and PCM ground?
Squeeze the knock sensor connector and it will come out. How do you know the wire is bad? Did it get burnt on the headers? A couple of options I can think of. You could buy a new connector and splice it in to a good part by the pcm wire. Or spice some new wire to the connector you already have. Have you tested the connector to see if it's getting 5 volts? I would try that before trying to splice some new wire in there.
Are you talking about the ground wire that is connected to the passenger side of the block? Or does that one come from the starter? If its the wire attached to the block, then its kind of a pain. You might have to remove the starter or y-pipe if you cant get access. Others should chime in here.
Z
Old Jul 18, 2005 | 10:51 PM
94TA25ann's Avatar
Z
I want to run a new wire from the pcm to the knock sensor connector. I also want to do the same with the pcm ground that attaches to the side of the block above the starter. I can get to the pcm ground wihtout any problem. I just need to know if there is a way to replace the wires with new ones or if you have to splice them. Here is a picture off shoeboxes website of the pcm ground wire that im talking about. http://shbox.com/1/g103.jpg In that picture you can also see the wire that runs to the knock sensor right below the pcm ground wire (looks like the green wire in the picture).
Old Jul 18, 2005 | 11:16 PM
ZMAN Z28's Avatar
I just spliced that ground wire along with o2, and knock sensor wire on the passenger side as I melted them together by my header. You would probably have to take apart the connector that plugs into the pcm to get the wires free. Sounds like a huge risk to me. Splicing is probably your best option besides buying a new wiring harness. I'd wait for some more replies about splicing. I've heard some people on the board not recommend splicing. At least pertaining to the o2 wires (not your problem). Some ppl say it affects the power rating of the wire. Me personally, I will splice into wires.
Z
Old Jul 19, 2005 | 12:03 AM
I would just splice out the damaged wire. Solder and heatshrink.
HectorM52
Jul 30, 2017 11:46 AM
Alex Barnes
Jan 24, 2015 10:21 PM
squarehead
Jan 15, 2015 07:02 PM
thenewkid
Nov 27, 2014 09:41 AM
IgorT.455/406
Feb 1, 2005 06:18 AM
