Oil pressure Question
Ok from the beginning. The clutch went out and the car sat for a week. Got the new clutch in and now the oil pressure isnt right. Ive never seen any problems out of the pressure gauge. The oil level is in the operating range but the gauge is telling me that the engine only has about 19 psi. Normally she runs at 35 at idle and about 40-45 moving. Oh yeah and the idle has come up to about 1100 rpm from 900. Any help would greatly be appreciated. Im only 23 and Im losing my hair and bankroll for this car.
Thanks Red
Thanks Red
Re: Oil pressure Question
Nevermind the location, I found thanks to the awesome pages of shoebox. but another question is the sensor supposed to be loose not turning loose but like the plastic is broke?
Thanks Red
Thanks Red
No it is not supposed to be loose, or able to wiggle.
It sounds like you may have cracked the outer pastic housing or something.
As far as the idle, Make sure you have all you O2's and everything plugged in!
Jul 4, 2005 05:00 PM
better than another rebuild. Thanks again.
