Oil pressure problem, need suggestions
Old Oct 10, 2005 | 02:30 PM
jkayner's Avatar
One day heading to work, I stopped at a red light, was idling for about a minute or so. My check guages light came on. I check all my guages and then notice my Oil pressure is sitting on 0! I immediately put it into neutral and gave it a little gas and the pressure would rise slightly (to about 10 maybe). I pulled over and checked my oil. It was at the lower part of the full mark. I stopped at a nearby auto parts and put some more oil in towards the upper half of the full mark. started the car up and it would go up to about 30. I decided to head home and not hurt the car. The entire time if i got caught at a light or stop sign, it would slowly fall back to 0.
I hadn't driven the car for a while because the registration and inspection was out. Things I have done so far. Emptied the oil, changed out oil and filter. Same thing happens.
I suspect the pump is going out, but what puzzles me is why, if you give it gas, the pressure rises to about 30, then falls to 0.
I dread having to change out the pump, can I check anything else before having to dive into this?
Old Oct 10, 2005 | 02:32 PM
Firehawk_Dude's Avatar
Re: Oil pressure problem, need suggestions
I would be happy it was the pump. Becuase that sounds like a case of some bad bearings.
Old Oct 10, 2005 | 03:16 PM
93turbo5oh's Avatar
put some redline 10w40 in it and a wix 51060 filter. see if that helps.
sounds like it was a quart low. which isnt a big deal. i have to run my car a quart low or the oil pressure isnt stable under hard accelleration above 4K rpm. i run the 10w40 redline and have more oil pres then i did with SAE 30.
Old Oct 10, 2005 | 09:05 PM
jkayner's Avatar
what bearings would those be?
Old Oct 11, 2005 | 12:33 AM
How many miles are on the car? Who put the cam in? Did you do lifters with the cam install or just the cam?
Old Oct 11, 2005 | 08:16 AM
1racerdude's Avatar
That would be your rod,mains and cam bearings. Sometimes the extra RPM's from a cam make the bearings wear real fast and blow the motor.
Old Oct 11, 2005 | 01:44 PM
jkayner's Avatar
I did the cam install with a friend. Did not replace the lifters. The cam is relatively small 218/230 @ .050 .495/.510 114LS.
Old Oct 11, 2005 | 01:55 PM
Z28SORR's Avatar
Have you checked the oil pressure sending unit and the gage. A hard line pressure gage is also a good backup check before going into the engine.
Old Oct 11, 2005 | 01:57 PM
1racerdude's Avatar
Put a manual guage on it and see if the OP really it low. If it is start pulling it to rebuild.
Old Oct 11, 2005 | 02:06 PM
I agree. Def. check w/ manual gauge first. Otherwise, sounds like cam bearings #1 and if not then I would think mains.
Old Oct 11, 2005 | 09:24 PM
bdc95ta's Avatar
I see you live in sugarland I live in cypress. If you did spin a bearing I'll help you take your engine out if you help me take mine out. I have a happy hooker to make the job easier. Let me know.
-brandon
Old Oct 12, 2005 | 01:53 AM
93turbo5oh's Avatar
i like angry hookers, the ***** is tighter.
Old Oct 12, 2005 | 02:49 PM
jkayner - Post up on what that gauge says when you get one on there.
Old Oct 13, 2005 | 08:04 PM
ZMAN Z28's Avatar
My car had close to your symptomsin oil pressure, but I had a miss. Oil pressure falling. No knock, but #8 plug had oil on it. Car also wasn't smoking other than normal. Turned out it was a broken valve spring. My car had 107K miles on it, so I pulled the motor. My bearings had some pretty good wear to them. But they were still ok. It was only a matter of time before I had a bearing failure any ways. But you could pull your valve covers to inspect for a broken spring. But anyways, more than likely its time for a rebuild.
ZMAN
Old Oct 14, 2005 | 10:35 PM
Brew8194's Avatar
my oil pressure sensor went bad a couple of times and the guage will not read right everything was fine with it though ok to drive i mean plenty oil....
