Oil pressure problem, need suggestions
One day heading to work, I stopped at a red light, was idling for about a minute or so. My check guages light came on. I check all my guages and then notice my Oil pressure is sitting on 0!
I immediately put it into neutral and gave it a little gas and the pressure would rise slightly (to about 10 maybe). I pulled over and checked my oil. It was at the lower part of the full mark. I stopped at a nearby auto parts and put some more oil in towards the upper half of the full mark. started the car up and it would go up to about 30. I decided to head home and not hurt the car. The entire time if i got caught at a light or stop sign, it would slowly fall back to 0.
I hadn't driven the car for a while because the registration and inspection was out. Things I have done so far. Emptied the oil, changed out oil and filter. Same thing happens.
I suspect the pump is going out, but what puzzles me is why, if you give it gas, the pressure rises to about 30, then falls to 0.
I dread having to change out the pump, can I check anything else before having to dive into this?
I immediately put it into neutral and gave it a little gas and the pressure would rise slightly (to about 10 maybe). I pulled over and checked my oil. It was at the lower part of the full mark. I stopped at a nearby auto parts and put some more oil in towards the upper half of the full mark. started the car up and it would go up to about 30. I decided to head home and not hurt the car. The entire time if i got caught at a light or stop sign, it would slowly fall back to 0. I hadn't driven the car for a while because the registration and inspection was out. Things I have done so far. Emptied the oil, changed out oil and filter. Same thing happens.
Re: Oil pressure problem, need suggestions
put some redline 10w40 in it and a wix 51060 filter. see if that helps.
sounds like it was a quart low. which isnt a big deal. i have to run my car a quart low or the oil pressure isnt stable under hard accelleration above 4K rpm. i run the 10w40 redline and have more oil pres then i did with SAE 30.
what bearings would those be?
I did the cam install with a friend. Did not replace the lifters. The cam is relatively small 218/230 @ .050 .495/.510 114LS.
I see you live in sugarland I live in cypress. If you did spin a bearing I'll help you take your engine out if you help me take mine out. I have a happy hooker to make the job easier. Let me know.
-brandon
-brandon
My car had close to your symptomsin oil pressure, but I had a miss. Oil pressure falling. No knock, but #8 plug had oil on it. Car also wasn't smoking other than normal. Turned out it was a broken valve spring. My car had 107K miles on it, so I pulled the motor. My bearings had some pretty good wear to them. But they were still ok. It was only a matter of time before I had a bearing failure any ways. But you could pull your valve covers to inspect for a broken spring. But anyways, more than likely its time for a rebuild.
ZMAN
ZMAN
my oil pressure sensor went bad a couple of times and the guage will not read right everything was fine with it though ok to drive i mean plenty oil....
