Oil pressure problem?
Old Mar 9, 2009 | 10:11 PM
jsm1986's Avatar
Hello i just recently bought a 95 z28 camaro with 118,000. miles
At idle the oil pressure guage is at the quarter mark(19-20 psi) on the guage when i accelerate the oil pressure riises to the half way mark (40 psi). Is this normal or does it indicate a bigger problem? When i first bought it i noticed that the harmonic balancer hub had a bolt missing and the engine would vibrate becauase of it. I immediately fixed it. but i have no idea how long it was like that. I had never noticed a drop in oil pressure before that. It was only after it was changed that i noticed it.
Old Mar 9, 2009 | 10:19 PM
mrmint69's Avatar
For a stock setup it is normal. Mine idles at 18-19 once it warms up and rises past the 1/2 way mark under acceleration.
Old Mar 9, 2009 | 11:01 PM
mike2244's Avatar
very normal, your engine only needs 5PSI for each 1000 RPM, aslong as you have that then you are good.
HectorM52
Jul 30, 2017 11:46 AM
Dmonty
Jun 2, 2015 11:19 PM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
