Oil pressure normal operating range?
Old May 27, 2007 | 02:30 PM
always faster's Avatar
Will im searching for my other problem i realise that my oil pressure is really high on my gauge(stock one).
When i start it,i get around 412 wich is excatly in the middle between the 275mark and the 550 mark
When it get worm the oil pressure would stay around 275 right in the middle of the gauge.
My last motor never reach those number.
Right now im running some 5w30 castrol mineral oil for my break in.I also got a new sending unit.
Is it good or bad ?
Old May 27, 2007 | 03:13 PM
1racerdude's Avatar
Oil pressure on a stock one should be between 0-50PSI.
On a built engine it is whatever ya set it at but NOT 275PSI.
Old May 27, 2007 | 03:31 PM
Is the stock gauge graduate in psi? Man im runnig right between the 275 mark and the 550 mark.It seem impossible
Old May 27, 2007 | 06:05 PM
1racerdude's Avatar
Should be in PSI.
Old May 28, 2007 | 07:12 AM
How the hell could the stock gauge be in psi.Normal people got around 60 psi when its cold and around 20psi when its hot.
If the stock gauge is in psi i would have over 275 psi off oil pressure in my motor...That doesnt make sens
Old May 28, 2007 | 07:33 AM
mdacton's Avatar
are you sure its in PSI.....not kpa or something like that? You close to canada?
Old May 28, 2007 | 07:41 AM
Exactly was i was trying to say in my bad english(sorry).The stock gauge is graduate like this= 0(start)-275(middle)-550(end)
There is no way that i would have over 400psi of oil pressure in my car
Yeah im from Quebec,Canada
Old May 28, 2007 | 07:47 AM
mdacton's Avatar
I would say your goood then....about half way. seems o.k.
maybe find a conversion chart......rule of thumb is 10 psi per thousand rpm's
6000 rpm= 60psi
hope that helps, Good day canadian
Old May 28, 2007 | 07:51 AM
6000 rpm= 60psi
Yeah i just found a pictures of a US cluster and yours are already graduate in psi,lucky for you : (start)0-(middle)40-(end)80
So mine is in KPA.
10 KPA = 1.4503773773020922 PSI
So when cold my 412 KPA = 59.7555479448462 PSI
And when hot my 275KPA = 39.885377875807535 PSI
So my car is perfect.
Thank you for you help
Old May 28, 2007 | 07:52 AM
aboatguy's Avatar
PSI = 0.145038 X kPa
Looks like he's good
412kPa is 59.755656
275kPa is 39.88545
Old May 28, 2007 | 07:58 AM
aboatguy's Avatar
Dayumm beat by a minute
Old May 28, 2007 | 07:59 AM
Lol thanks for double checking my numbers.
Look like my oil pressure is good
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
transam_388
Mar 15, 2015 11:53 AM
jayblev95
Dec 1, 2014 06:55 AM
