oil pressure goes to 0 under hard braking
Old Jun 12, 2007 | 12:53 PM
bufmatmuslepants's Avatar
ever since ive had the car, over a year and 15000 miles, every time i hit the brakes hard when coming to a stop sign or whatever, my oil pressure goes to 0 and the light on the dash says "CHECK GUAGES" then once i blip the throttle just a tiny bit or start to drive again it goes right back to normal. is this because the oil is shifting in the pan and the oil pump cant reach it? does anyone else have this happen? the motor doesnt miss or studder or shake or anything when it does this just the guage goes to 0 and nothing else changes. anybody have any ideas?
Old Jun 12, 2007 | 02:21 PM
Z28SORR's Avatar
Lots of possibilities. You could have a loose pickup or it may have fallen off.
You could drain the oil and tap on the pan and see if anything is rattling around.
You could not have enough oil in the pan. Because you didn't put enough in or it got pumped up into the valve covers or intake gallery. Could be caused by high volume pump or glogged drain back holes. Drain the oil and add 4 qts let it sit then check where it comes on the dip stick, maybe the stick is wrong.
Really thin oil. There are other things like the stock pan baffles came off, etc. but they would be very unusual.
Old Jun 12, 2007 | 06:17 PM
1badasZ's Avatar
mine was doing the same thing one time cause the pickup had fallen off
Old Jun 12, 2007 | 06:20 PM
camaroz28_97's Avatar
Same here
Old Jun 12, 2007 | 09:17 PM
RedLT4Mike's Avatar
Originally Posted by camaroz28_97
Same here
same with my old engine
Old Jun 12, 2007 | 10:07 PM
hotrod18_69's Avatar
"Note to self" always weld the pickup's on..
My guess is that the pickup fell off..
Old Jun 15, 2007 | 01:42 PM
damnit...guess i got ANOTHER project now. im dropping my whole front suspension to replace it with all new components, think it would be wise to do this when i drop the K member? or is it easily accessible without dropping it?
Old Jun 15, 2007 | 02:01 PM
95ttoplt1's Avatar
Same here Oil pump pick was laying in the pan. Weld it, there was a guy a couple weeks ago that had the bracket break off his bolt on pick-up and it fell off again, bad luck.
Old Jun 15, 2007 | 03:47 PM
96LT1TX's Avatar
One more vote for "get your oil pump intake tube WELDED on". I found a local shop to get it braized(sp?) all the way around on the bottom of the tube. Trust me, this is probably your problem because I "fixed" this problem about 5 times before it was finally done. Dont have someone just tac it in a few spots either, this will not work. You need a good bead on the lip of the intake tube a good halfway around the tube.
Old Jun 15, 2007 | 04:17 PM
ulakovic22's Avatar
I'm surprised that you haven't had to rebuild it by now if it's been a problem for over a year. Hopefully your bearings aren't toast.
HectorM52
Jul 30, 2017 11:46 AM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
jayblev95
Dec 1, 2014 06:55 AM
Jul 4, 2005 05:00 PM
