Oil Pressure Gauge
Old Apr 23, 2006 | 08:25 PM
ChrisUlrich's Avatar
Oil Pressure Gauge
Ok... motor is a 383. Eagle Crank, Eagle Rods, SRP Pistons, Clevite Bearings, LE3 Heads, LE3 Cam, LE Intake, etc... Just stating this fact so just you know what it's in it to see how much the oil pressure differs from stock.
When the car starts, it's at 60, if you happen to get on it before it's fully warmed. It shoots to about 70-75.
Once it's warmed up, it's usually pointing straight up (40psi). If you're at idle, it sits firmly at 20-25psi.
Today, for some reason, the gauge from to 0 at idle? But then it shot right back up and was doing it's usual thing. Then again, at idle... it drops back to 0 and the "Check Gauges" light comes on. The car runs fine as of now (It just happened). But what are the possibilities of it being a mechanical problem and the gauge not being correct?
Old Apr 23, 2006 | 08:29 PM
94zrag's Avatar
Re: Oil Pressure Gauge
From the sound of it, it's probably the gauge. But I wouldn't drive it until you know for sure. It could be as simple as a loose wire to the pressure sensor, but better safe than sorry.
Old Apr 23, 2006 | 08:35 PM
Where could I find the wires to check it out? I'll run them all the way through and check connections.
Old Apr 23, 2006 | 10:10 PM
94zrag's Avatar
http://shbox.com/1/oil_pressure_sensor.jpg This is where the pressure sensor is. I actually had the sensor disconnect itself once, and hopefully thats your problem as well. And not to sound like an idiot or anything, but you did check the oil level, right?
Old Apr 24, 2006 | 01:39 AM
Yea... the level is good. It drops to 0, but it shoots right back up. It only happens at idle too... as soon as I goose the throttle, it's fine. I am going to check it tomorrow. Thanks!
Old Apr 25, 2006 | 05:29 AM
Excuse my ignorance but... can you have an oil leak from a bad sensor?
Old Apr 25, 2006 | 02:07 PM
No one?
Old Apr 25, 2006 | 02:13 PM
Javier97Z28's Avatar
Moderator
eh, unless the sensor is loose for some reason.. no.
Old Apr 27, 2006 | 12:22 AM
Z95m6's Avatar
I had a pretty bad one on my old 65 falcon. I left the car running and came out to find the car just dumping oil on the ground. It ended up being the oil pressure sensor. It was just leaking right out one of the seams of it.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
KYWes
Apr 15, 2015 05:48 AM
Z28countrymama
Jan 22, 2015 02:50 AM
